gear box fault - RESOLVED
Received 4,317 Likes
![Frown](https://www.jaguarforums.com/forum/images/smilies/frown.gif)
She gets a piggy back ride tomorrow to the indie for a look. I've read the previous threads on this - so hoping it doesn't require replacement and can be repaired.
Either way, hope to have her back on the road this weekend - driving a Smart car just does not take the place of my Jag!!!
regards,
steve
Hope it's not too serious! I had a gear box fault that showed up with a Throttle Body fault (can't remember which one). I disconnected, cleaned, jammed and reconnected all TB connectors and the gearbox error never came back. So you see, it may well be a simple electrical thing that has nothing to do with the gearbox
The following 2 users liked this post by jafari:
Bob OB (06-04-2014),
Sir Alex of Yotto (03-12-2016)
well so far they found four codes in three separate systems that indicate a probable issue with the transmission speed output sensor; checked the fluid level and inspected the fluid. The level is o.k., but the condition of the fluid is burnt and black.
dropping the pan for further inspection
If you have not done so - check/replace the transmission fluid - sealed for life is BS.
JimC64 (06-06-2014)
Gus (05-21-2014)
Gus (05-29-2014)
sklimii (06-04-2014)
cjd777 (06-06-2014)
