Gearbox fault when selecting reverse
Our 1998 XK8 develops a gearbox fault when selecting reverse gear. the fault appears on the dash and the car goes into limp mode.
It appears to happen when the gearbox goes into reverse with a clunk. It appears that the gearbox and engine speed are not in synch. If I select neutral for a few seconds (and let the engine revs drop completely) then select reverse it does not fault.
If I restart the engine the fault disappears. The gearbox seems to be working fine otherwise.
Has anyone come across a similar problem and have any suggested solutions?
Thanks for listening!
Nigel, Cowes, Isle of Wight.
RCSign (01-04-2011)
Woznaldo
09-26-2015 11:02 AM
driver safz
09-26-2015 06:01 AM
