Gearbox Lurch Help
A small lurch on the 2-1 shift when coming to a stop is reasonably common and seems to be a trait of the 6HP26 regardless of make. But on the 1-2 shift issue are not common.
My first thought would be to check the fluid level, or just do the filter and fluid change if you don’t know the history of the car. These can be sensitive to fluid level, too little or too much can cause strange behavior.
CA Jag (07-18-2021)
What's a reasonable drain and fill cost? Here, Jag shop quote seems ridiculous. 425 to do 1x drain/refill/filter. Maybe your 800 full service means 2x?
Local "does any brand trans" shop is 150 1x and it needs to be done 2x. I have the ATF (37 at Walmart, bought extra) and filter (45 overpriced at local parts store) so total 232. At my age, getting under the car isn't an option.
Re-doing the shift adaptations seems to be the most help, but the process requires the dealer software and the process is bit of a PITA. People have found more recently that dealers are refusing to mess with the software on the x100 (or playing ignorant of knowing how). I think there are other tools that can also do it but I don't have any specific recommendations on that front.
There are ways to set up the dealer software on a laptop and do it yourself if you can get a compatible cable, or there are some forum members that have this setup already.
wally509
04-13-2009 09:48 AM
Toller
12-17-2008 11:07 PM
