Gearbox problem with P1748 code
Gearbox problem with P1748 code (Edit:Now with Answer)
I haven't had much of an opportunity to use my Jaguar over the past few months resulting in a drained battery.
Today I went to use it, the battery wasn't very well charged, but had enough life to start it without any problems.
I noticed selecting gears had a harsh jolt, and driving off it wouldn't change gear, I think it was stuck in 2nd?
I also got the message which says "Gearbox Fault"
I read the fault code and retrieved P1748 which I believe is Pressure Regulator 5.
What exactly is it? Is it electrical or mechanical? Solenoid?
What does this do?
And how much of a job is it to change it?
From what I can gather it lives in the gearbox and going to be a nightmare job.
Thanks in advance.
What does this do?
Thanks in advance.
What does this do?
Thanks in advance.
What does this do?
Thanks in advance.
With a weak battery, the heavy load of the starter motor can drop the system voltage so low that the electronic modules can malfunction.
Thanks for the advice guys.
I charged the battery up over night.
Started it this morning and it had plenty of life.
Cleared the codes.
Selected reverse gear with a harsh jolt, backed out the drive, selected drive (again with a jolt) and drove down the road but would not change gear.
So went into a side road, did a few selections from Reverse to Drive, then turned it off and on again (I find this fixes a lot of problems)
Then pulling away it was changing up gear and all back to normal
So is this a sign that I have a component about to fail or something is on the way out?
I know my battery is about 4 years old and getting tired, so I think I will get that replaced.
Will use it all this week and see how it performs.
Thanks again
Cleared the codes.
Thanks again
Hello, thought I would add the conclusion to this thread now I know the answer I cant stand threads where there's no conclusion to the problem.
Anyway, regarding the P1748 error code which was causing "Gearbox Fault" message and would not change gear accompanied by a harsh jolt when selecting any gear.
I did try installing a new battery which unfortunately made no difference and checked the oil level which was fine, so I took the car to an independent Jag dealer.
The outcome was my initial suspicion of the Pressure Regulator which is located in the Conductor Plate in the gearbox.
It has now been replaced and everything is back to normal
Thanks for all your pointers.
Lawrence
Lawrence
The following 5 users liked this post by sweatyfox:
ccfulton (07-08-2014),
Don B (03-05-2020),
Paul Pavlik (07-08-2014),
RJ237 (07-08-2014),
sklimii (07-08-2014)
