Gearbox/Transmission
Gearbox/transmission .XKR
On hard acceleration up a steep hill I get all the right noise from the engine and rev counter go`s up past 4500/5000 ,but there is little change in the cars speed ?
If you lift off there is a surge forward as the gearbox changes up.
I have over 100000 miles on the clock and no mention of a gearbox oil change.
advice please. Oil change, or worst ?
Well I phoned my Independent Jag garage today .To be told not to waste money changing the oil and filter (He said that was £450 + vat) as it was the cones in the clutch and that it would need a new /reconditioned gearbox costing £2200 + vat.He did say in fairness that he would take some readings, but was certain it was a broken gearbox?
The engine with sport mode engaged will stop revving at 4000 rpm and the car stops accelerating, if I lift off the car will keep on accelerating but in a higher gear?
Well, it certainly could be a complete failure but your comment about ' . . . going up a steep hill . . . . certainly sounds like the pressure pump pick up is sucking air when the ATF shifts to the rear of the pan.
Any sign of leaks on garage floor or drive way?.
Why don't you ask them to at least verify that the trans is full to specifications. That couldn't take but a few minutes. They don't even have to let the trans cool to the correct temp. Open the fill port and if only a little or no ATF comes out that is the problem. If it does then it may well be the full monty.
bt_bob1 (02-10-2014)
Well, it certainly could be a complete failure but your comment about ' . . . going up a steep hill . . . . certainly sounds like the pressure pump pick up is sucking air when the ATF shif ts to the rear of the pan.
Why don't you ask them to at least verify that the trans is full to specifications. That couldn't take but a few minutes. They don't even have to let the trans cool to the correct temp. Open the fill port and if only a little or no ATF comes out that is the problem. If it does then it may well be the full monty .o
If you read around these forums, you'll see that our valve bodies are what typically begins to fail...not the hard parts. If you're fluid is not low, you could still be looking at only a rebuilt ZF valve body replacement, which isn't THAT bad, in comparison.
Now, a flashing D on your gear selector, that may be something more serious. You definitely need your codes read to see what is going on there.
So fingers crossed the g/box is O.K. Does this hose carry oil or is it for air? Have you looked at it to see the hole yourself? Are you handy with the spanners? Can you seal ( self vulcanising tape/duck tape ) the hole so you can try the car again and verify if this is the problem? This would only work if the hose was for air obviously, if its for oil you would need to top up to the correct level. IMHO worth doing if you have to wait for over 2 weeks though, I would have to try it to put my mind at rest.
Hope it works out for you.
ArtyH
ArtyH
On taking my car to a independent he spotted that the hose between the S/C and ecu had developed a hole He has ordered the part about £8 $12 . But is so busy he cannot do the job for 2 weeks
How difficult is it to remove the S/C and the bits, to get access to change this hose
Thankfully there was nothing wrong with the gearbox it was a small hose off the back of the S/C with a hole in it. the one on the engine oil fill side.It has been contaminated with oil and had swollen up and burst, Hence the acceleration stopping at about 4000 revs and surging forward as you lifted off and the car changing up a gear.
anjum
08-28-2012 08:41 PM
BusinessConnected
03-22-2008 09:35 AM
