Gearbox won't shift into park.
I would appreciate some advice from you kind soul's again.
I took the XKR for a drive and drink today but when I got to the garage to fill up the car would not shift in to park, this problem has not happened before.
The only thing I did different (project car) was cycle the gearbox in to 3rd and 4th gear while driving.
Any thoughts would be great?
Hello
Yes I have experienced this problem from time to time in my 99 XKR. I found it happened after vigorous driving and I just let it sit in neutral for a while, to let the engine temperature and gearbox oil cool a little. Then I put my foot hard on the brake, revved the engine and let the revs go and it goes into park ok.
That worked for me, but you might need a gearbox oil change, I would consult a mechanic. They dont last forever whatever people say and can be a bit tempremental at high temperature.
Probably not a big issue but I would get it looked at sooner rather than later. Contrary to what they say, the early 5 speed auto boxes are very good but need looking after at high mileage.
Hope this helps mate
Smitty 😀👍
Smitty 😀👍
The ZF trans is electric and linkage that is driven by your shifter cable and that cable may need adjustment . This is a link to a TSB on how to adjust the shifter cable.
http://www.jagrepair.com/images/TSB/307-01-1.pdf
Truck Graphics (06-02-2022)
Received 1,684 Likes
Z
interesting …. Do you happen to have any documentation that could be linked to the comments ?
I would love to read up on any 722.6 transmission information. My knowledge of the Mercedes transmission is sadly lacking.
Z
All of us with the 4.0 XKR have the Mercedes 5G-Tronic 5 speed gearbox, which was widely used across quite a few different brands and, as you say, has a very good reputation. The 4.0 XK8s use the ZF 5HP24 which had a design flaw causing premature A drum failure, hence its poor reputation from new. I think ZF updated the gearbox in 2001 and many people will have rebuilt their original gearboxes with the upgraded parts by now, but this is a problem the Mercedes gearbox never had.
Sorry but I have not had the opportunity to work on the Mercedes G5 Trans. I looked on the XK8 workshop manual to see if it had it listed but did not find it but I would assume it is near the XK8 procedure. I hope someone with that experience will chime in.
http://www.jagrepair.com/images/Auto...p%20Manual.pdf
Phil m (05-30-2022)
Incase this helps someone in the future.
To fix the problem all I had to do was change the Gear change control Solenoid situated to the NE of the Jgate.
£10 part.![Icon Beerchug](https://www.jaguarforums.com/forum/images/smilies/icon_beerchug.gif)
https://www.autoreservejaguar.com/xj...interlock.html
£10 part.
The following 2 users liked this post by Phil m:
Dr. D (09-16-2022),
Timeisrelative (09-19-2022)
hibernianscribe
07-01-2014 12:56 AM
