Gen III throttle body failure?
This is it and I use it all the time http://www.crcindustries.com/auto/co...x?PN=02085&S=Y With NO adverse affects.
When I apply the Di-Electric grease I use it sparingly. My purpose in using it is to prevent moisture from entering the strike point of the connector eliminating the sporadic operation related to corrosion / oxidation that often takes place on connectors that often disrupts the operation of this and other cars. I also use it to prevent the possibility of tracking in the connectors that could confuse the vehicle operation that is at times related to contamination, moisture and poor connections. If used correctly as the label indicates it will serve you well. Something you need to know, I do not recommend anything I do not use and cannot stand behind. This produce is designated for this use and I will continue to use it this way. Do not let the term Di-Electric confuse you! You can continue to deal with a poltergeist episodes, I will continue to eliminate them in my car.
xjrjag
09-27-2015 01:53 AM
