getting tensioners replaced
Of course, this is for the Secondary Tensioner replacement only:
RockAuto Parts Catalog
randyb (05-01-2013)
The Chains are contained inside the (Valve or Front) Covers.
Replacing the Primary Tensioners would require removing the Engine Front Cover (MUCH bigger job) and then would require replacing (or re-using) the Front Cover Gasket.
Note: a alternate for the Valve Cover Gaskets is the Fel-Pro set:
RoyLittle0
05-25-2023 02:38 AM
KarimPA
09-12-2015 08:15 AM
