Getting the thermostat gasket to seal?
I replaced the coolant tower a few months ago with the aluminum casting.
I've had problems with sealing at the thermostat housing, on removal it looks like the coolant was flowing through the paper gasket. Bolts were tight.
The top cap of the tower also refuses to seal, even after I put RTV on it. The casting is quite rough so I might try the plastic cap.
Yesterday I also pulled the upper manifold to check the condition of the valley hoses and look for other leaks. Anything else to check while I have it off?
Any tips for getting the gasket/cap to seal? Is there a specific kind of RTV to use?
2000 XK8 Coupe. Thanks,
edit: Looks like maybe the paper gasket that came with my kit is incorrect.
NCA2269CA ribbed gasket at base of tower
NCS2246BA seal that goes around thermostat
