Glasspar G2 with XK8 running gear
Building a Glasspar G2 with running gear from a XK8 donor. Want to eliminate ABS. What is the best approach to the computer systems;
1. Modify/reprogram the ECM. Is this possible?
2. Install a stand alone computer system. Is there a system that can incorporate the transmission computer? Use a manual transmission?.
3. Convert to a carburetted intake and manual transmission. Has anybody tried to do this?
Would love to hear what others have done. Regards.
The following 4 users liked this post by paddycan:
Timeisrelative (02-22-2020)
My best guess is that it would be easiest to build a little computer to emulate the ABS module.
That way you can still maintain whatever functions of the electronics system that you want, while also deleting the abs functionality and the pump/distribution block.
You can delete whatever features you want from the car, go a manual transmission, a carburetor instead of injection.
You just need to have the knowledge of how to emulate the computers of these systems so that your ECM doesn't get really pissed off.
Timeisrelative (02-25-2020)
