Got code P0010 CPA circuit open
I changed a vacuum hose on Saturday and now I am getting a 'Camshaft Position Actuator circuit open bank 1', I have gone over everything I disconnected and made sure I re-connected them.
So where is the CPA?
Is it the 2 sensors on top of each of the valve covers toward the front?
This code is for the variable cam timing oil control solenoid, either a solenoid malfunction or a circuit malfunction. Check the connectors to the VVT solenoids on the valve cover and make sure you haven't disturbed the right hand one. If you want to troubleshoot it, you will need a subscription to Alldata.com so that you can get all the connector pin locations and procedures to check it.
99xk8guy
06-05-2023 06:28 AM
