Green antifreeze
Is it ok to use green antifreeze coolant in these cars? My car, as far as I recall, has always had the green stuff even though the label says to use the orange stuff. I do know not to mix them as this would cause a chemical reaction that results in a goop that clogs up the cooling system.
I'm using Prestone long life antifreeze coolant, it's green, and says do not mix with water (it's pre-diluted), I've yet to have a problem with this coolant in the last 4 years. I'm just wondering if the next time I flush the system, I should top it off with the orange stuff instead?
There are two kinds of antifreeze: The kind bought by obsessive compulsive owners and the kind used by everyone else.
I have used the Autozone Yellow mix w/ anything in all my cars w/o a problem for many many years. As far as I know, if it says universal mix on the label, the green is the same. The single caveat is that I replace the coolant at least every year because I am either performing work on the cooling system; or as preventive maintenance care. I never reuse any coolant. Always fresh. And always distilled water... never from the tap.
All of the problems associated with Dexcool are associated with neglecting to replace coolant and are a result of leaving the coolant in five or ten years wherein it turns to what you and I would refer to as slush. And to answer your Q, no I would not add Dexcool to your green Prestone. But I would drain and replace your existing Prestone as often as possible.
Some European owners need to be careful with the phosphate content off their antifreeze reacting with aluminum; but that type of coolant is not available in the US and is a non issue here.
The following 6 users liked this post by GordoCatCar:
Dennis07 (03-24-2013),
giandanielxk8 (03-24-2013),
MRomanik (03-25-2013),
Norri (03-24-2013),
Powdercoater (04-08-2013),
and 1 others liked this post.
Jaguar Forums Editor
Jaguar Press release
09-30-2015 03:08 PM
