gremlins on the dash intrument cluster
![Exclamation](https://www.jaguarforums.com/forum/images/icons/icon4.gif)
![Icon Dunce](https://www.jaguarforums.com/forum/images/smilies/icon_dunce.gif)
![](https://www.jaguarforums.com/forum/images/kirsch/misc/progress.gif)
Charlie Galea (09-06-2012)
This code indicates an issue with the passenger seat belt buckle. It could be a broken wire or a short to ground but the commonest cause is a dirty 'Hall Effect' sensor in the buckle.
Be very careful when cleaning or removing the buckle. As another member found recently, the wires to the main harness connector are easily broken and the buckle is frighteningly expensive.
Charlie Galea (09-08-2012)
Charlie Galea (09-09-2012)
Sorry, I may not have been very clear in what I requested. I wanted you to check pin 1 to ground and pin 2 to ground for 12 volts, not between pins 1 and 2. I am not sure if that is what you did.
Thanks for your interest in my problem
Plug in the dimmer module and pull fuse 18 on the passenger side dashboard fuesbox...any change in the problem?
Fletch44
09-28-2015 02:21 PM
