Guess that sound! And help me, 00 XKR won't start.
https://*******/OKjx
For the past couple of months my vehicle has had a hard time starting when cold, sometimes you would have to turn the key twice but never any problems when running, today it finally won't start! It's not giving me any diagnostic codes just the p1111. I think it's my starter or fuel pump, could someone with more knowledge listen to the sound it makes when I try to start it and tell me what they think?
Thanks!
Thanks!
Two things to check the first is to swap your starter relay with another like relay and if the problem still exists check your ground at the battery and the one from the frame to the transmission bolt. It is on the right side of the trans just below the starter. The clicking leads me to believe that the starter solenoid is intermittent. Question does it do it when you try to start it in "N"?
Gus, responding to your pm now.
I did some basic troubleshooting with no luck.
1. Battery load tested good.
2. Swapped the starter relay, no change.
3. Checked fuses, all good:
fascia fusebox - driver's side
#6 5amps centre console switches, key transponder module, convertible top header console, rain sensing
engine compartment fusebox passenger side - within bulkhead extension
#3 25amps starter solenoid
engine compartment fusebox - left-hand side
#5 10amps starter relay, engine controle module
4. Tried another key, no change.
Brian BigSkip Skipper
01-27-2016 02:35 AM
