H&R lowering springs
Should not be an issue if you have stock wheels and all model years are the same.
If you're worried, there are other options that lower the car a bit less:
Mina Gallery is 1.2
Adamesh is 1.0
I have a full set of Adamesh springs on my XKR. Improved the look but didn't hurt the ride or cause any other problems.
Mina Gallery is 1.2
Adamesh is 1.0
Mina Gallery is 1.2
Adamesh is 1.0
Mina Gallery is 1.2
Adamesh is 1.0
I put them on my XK8 and they worked out perfectly... I have 20" wheels and have no problems. You also will need to change out the spacer between the rear axle(s) and the wheel(s) to adjust the rear camber because the lowering of the car brings the top of the wheels inward. And now that I looked at my signature pic I may need to replace it to show the car lowered...
Received 4,303 Likes
Johnken (08-25-2020)
JaguarXKR - try DCR Autoparts - they offer both standard and lowering springs - link below
https://www.xk8-parts.com/2016/10/ja...-gallery-page/
multistrada74
11-06-2022 10:52 AM
