Hard accel gear change gerk after ECU reset
Jaguar XKR 2001 54K miles
Hi I recently changed my MFA and in the process I reset the ECU by disconnecting the battery for 24hr.
Now after reconnecting the battery and driving roughly 50-60miles the gear changes gerks when accelerating hard (this has been like this only since the ECU rest) i.e. upto 5-6K revs. Before the reset everything was fine. Engine run great with new MAF and is much more responsive. I used to get "Trac Not Avail" when starting the car after leaving it a day or so. This error went as soon as the car started and I never got this error when starting a warm car. The error has gone since the ECU reset.
Now I assume the car would have cycled all the tests by now. Do I just need to drive more miles to get the gearbox to re learn my driving style ? or is there something you should do to reset transmission?
Note I have flush the transmission (ATF oil) and put a new filter and elec connector 4K miles ago and had no trans problems until the ECU reset.
Simon
Simon
H20 dug up the trans re-teaching procedure for another recent thread. Might be worth resetting the system again and trying it.
Check out post #8
https://www.jaguarforums.com/forum/x...lipping-73576/
Check out post #8
Check out post #8
Check out post #8
Interesting but that problem is for the ZF Transmission. The 2001 XKR has the Mercedes transmission W5A580 (MB722.6). But my guess is it is a learning problem.
So disconnect +ive and earth from the battery and short, I assume this is ok to do and will reset the trans modual ???
Simon
