hard reboot
Old 04-01-2018, 01:18 PM
magnum454's Avatar
Default hard reboot
How is a hard reboot done on 2000XK8?
Old 04-01-2018, 01:39 PM
jeremys's Avatar
You will find a good write up of the hard reset procedure in the sticky /diy just below the audio section, hope this helps
Jeremy
magnum454 (04-01-2018)
Old 04-01-2018, 01:40 PM
RJ237's Avatar
Received 2,808 Likes on 2,241 Posts
Disconnect the negative cable at the battery and touch it to the positive terminal for 15 sec.
The following 2 users liked this post by RJ237:
magnum454 (04-01-2018), Orthodixie (04-02-2018)
Old 04-01-2018, 03:34 PM
Gus's Avatar
Gus
Gus is offline
Received 2,213 Likes on 1,702 Posts
Use this link to see how to do it.
The following 2 users liked this post by Gus:
Old 04-01-2018, 05:37 PM
GGG is offline
Received 16,861 Likes on 12,186 Posts
Now you know HOW, the obvious question has to be WHY do you want to do a hard reset?
It will only reset 'learned' settings such as fuel trims to default values and isn't a method of clearing error codes.
The following 2 users liked this post by GGG:
jeremys (04-02-2018), Orthodixie (04-02-2018)
no support
40
06-26-2017 02:04 PM
jimlombardi
10-27-2011 09:11 PM
edtexas
01-18-2011 10:21 PM
govatos
08-09-2010 08:40 PM
JamesWalker
04-28-2010 09:48 AM
Quick Reply: hard reboot
