Hard reset
Old 12-01-2015, 08:06 AM
dennysjag's Avatar
Default Hard reset
Touching the negative battery cable to the positive for 10 seconds scares the heck out of me. Is the positive lead still connected? Is this not shorting out creating sparks? I would love to do it if someone can assure me of the process. I don't want to fry the cat
Harley N (07-06-2022)
Old 12-01-2015, 08:13 AM
RJ237's Avatar
Received 2,801 Likes on 2,236 Posts
That's exactly correct, and it's even in the JTIS.
Old 12-01-2015, 08:57 AM
dennysjag's Avatar
Default Let the Sparks begin
Gonna try it hope I don't fry it
Old 12-01-2015, 09:36 AM
test point's Avatar
Received 1,111 Likes on 932 Posts
You remove the negative cable FROM THE BATTERY POST and touch the cable to the positive post. Nothing at that point is connected to the negative post, nothing sparks.
The following 3 users liked this post by test point:
Harley N (07-06-2022), RJ237 (12-01-2015), zray (07-06-2022)
Old 12-01-2015, 11:25 AM
Received 2,263 Likes on 1,845 Posts
Why do you feel the need to do this?
Old 12-01-2015, 11:28 AM
cjd777's Avatar
Received 1,348 Likes on 744 Posts
Well, Denny, you are a poet and don't know it.
"Gonna try it hope I don't fry it" Hope it will clear your problems
Wayne
Old 12-01-2015, 11:53 AM
Gus's Avatar
Gus
Gus is offline
Received 2,213 Likes on 1,702 Posts
See if this helps.
Link.http://www.jagrepair.com/HardRestProcedure.htm
Gus
www.jagrepair.com
Old 12-01-2015, 07:21 PM
dennysjag's Avatar
Thanks for all the replies, I just acquired the 2000 xk8 several weeks ago.77 k on it. On the 100 mile trip home the car gave alot of warnings then cleared themselves. It has driven reasonably well altough it seems that maybe the parameters that can be reset with a hard reset might improve overall. Is there any harm in executing this manuver?
Old 12-01-2015, 07:41 PM
test point's Avatar
It will take a few miles to stabilize the Long Term Fuel Trim but that is automatic. Many think that the ZF 5hp24 transmission 'learns' shifts based on your driving but that is not true. It shifts based on a number of programs affected by how you drive.
You will loose radio programming as well as seat programming. Nothing that cannot be resolved in a couple minutes.
dennysjag (12-01-2015)
Old 12-01-2015, 08:05 PM
No, but it won't address what apparently went wrong. Why not read the codes instead of wiping them out?
dennysjag's Avatar
I read somewhere on the forum about having to reprogram the tps after hard reset. I will look for it and execute this plan this weekend
Old 12-01-2015, 08:07 PM
dennysjag's Avatar
I will have my mechanic pull the codes before I reset. Thanks good advice
Old 12-01-2015, 10:51 PM
MediaBobNY's Avatar
You'll also need to reset the windows, and some cars (e.g. mine) will ask for the radio code.
Old 12-02-2015, 04:29 AM
multiplecats's Avatar
I've done a hard reset a couple of times but have never done this.
Old 12-02-2015, 04:32 AM
B o B's Avatar
That's the clearest advice I've seen on this subject. I too had the same concerns as those stated above. Thank you
The following 2 users liked this post by B o B:
Harley N (07-06-2022), test point (12-02-2015)
Old 12-02-2015, 08:24 PM
Gus's Avatar
Gus
Gus is offline
Doing a hard reset will not clear the OBDII codes and a reset on the TPS is not necessary on a hard reset.
Old 12-02-2015, 08:32 PM
Received 8,078 Likes on 4,873 Posts
Be aware of the CAN failure regarding the INSTPK.
Read the TSB and determine if it applies.
bob gauff
File Type: pdf
Old 12-02-2015, 08:34 PM
Torrid's Avatar
Actually it will reset codes. It's worked for me the two times I needed to clear a code on my VDP after a repair.
Old 12-03-2015, 03:44 PM
Gus's Avatar
Gus
Gus is offline
Did a reset on a car today and it did not reset the codes like I said.
Gus
www.jagrepair.com
Old 12-03-2015, 04:58 PM
Torrid's Avatar
Gus
JagRepair.com - Jaguar Repair Information Resource
Hmmm, interesting. I wonder why it works on my XJ.
Quick Reply: Hard reset
