Hard reset?
Old 08-13-2016, 01:41 PM
Richxk8's Avatar
Default Hard reset?
Does doing a hard reset clear "C" as well as "P" codes or do "C" codes have to be cleared using WDS, etc?
Old 08-13-2016, 01:54 PM
GGG is offline
Received 16,861 Likes on 12,186 Posts
If only DTC's were that easy to remove!
A hard reset doesn't even clear Pxxxx codes. It only resets learned settings in volatile memory such as fuel trims back to default and window travel limits.
Old 08-14-2016, 10:29 AM
Richxk8's Avatar
That's what I thought. If the part has been repaired will the CEL/DTC eventually reset or must it be done using the factory software?
Old 08-15-2016, 02:16 AM
JagV8's Avatar
Received 4,535 Likes on 3,944 Posts
Depends what the fault was.
Old 08-15-2016, 10:49 AM
Richxk8's Avatar
I have a "C1137" ABS Module Failure. Had it repaired but since I still have the C1137 code not sure repaired module is good. So, should I just go have it reset or wait for several drive cycles. Only issue now is no ABS, Trac or ASC. Still drivable.
kingnero
05-05-2020 12:46 PM
Softball60
08-04-2016 05:05 PM
Anthony8858
07-25-2016 11:06 AM
max224
07-19-2016 08:17 PM
peeterak
07-18-2016 01:10 PM
Quick Reply: Hard reset?
