hard start but once started runs fine?
Old 07-23-2022, 07:10 AM
Markmbaha1's Avatar
Through all these suggestions and weaving through the significant differences in fuel sytems across years and R vs X I've never solved my intermittent long crank starting issue. I can not resolve it. Is it just these cars are inconsistent starters? It's very frustrating.
Old 07-23-2022, 10:52 AM
JagV8's Avatar
Received 4,538 Likes on 3,947 Posts
What have you done via OBD?
Not that. It's always due to a fault.
Markmbaha1 (07-23-2022)
Old 07-23-2022, 10:58 AM
Markmbaha1's Avatar
I've tracked about everything electronically trackable via OBD, cleaned MAF, 2 hard resets. No lights, no messages, no warnings. The only thing I've not done is drive much since resets. Onky driven 15 to 20 minutes once and a few minutes second. (It's raining a lot here and it doesn't go out in rain or on wet roads) .
Old 07-23-2022, 05:43 PM
JayJagJay's Avatar
Received 1,296 Likes on 897 Posts
It's a fueling problem. I'd bet my pinky toe!
Old 07-25-2022, 02:30 PM
JagV8's Avatar
Got P1111?
If not, which OBD monitors are unhappy?
Markmbaha1 (07-25-2022)
Old 07-25-2022, 02:37 PM
Markmbaha1's Avatar
Got P1111?
Thats the good code. It means the scan cycle has completed. But yes akways had P1111. No other codes or lights.
Old 07-26-2022, 11:26 AM
JagV8's Avatar
That's encouraging.
If things like IAT & ECT are plausible values (the car just has to trust them, you can go by how hot you know the environment is), then it probably means it's something like an intermittent signal or an air leak that is only sometimes there. Or an ailing fuel pump. Or... well, the other things involved in starting
Markmbaha1 (07-26-2022)
LeJaguar
05-31-2021 12:23 PM
ahunt4
04-08-2015 08:44 PM
jkmspartan
XJ40 ( XJ81 )
09-03-2013 09:03 PM
johnnyd123123
XJ40 ( XJ81 )
01-17-2013 06:10 PM
Reverend Sam
09-09-2011 07:33 PM
Quick Reply: hard start but once started runs fine?
