Has anyone cut their springs to alter the ride height?
Meant slot
The "I" and "O" are next to each other and hit one and not the other. I had the acentric bolt fitted but it didn't provide enough movement so they had to elongate the slot. The tire place I used once they had the shims for XKRacer had no other problems though I wish I'd thought to have all of the spring and shock mounts and bumper stops replaced at the same time (the rubber parts were pretty much shot). Would have saved a ton of money later.
Bill Swift (02-11-2014)
I'm sorry Rob, I'm lost, what do you mean by I and O?
The car isn't stripped at the moment and I can't imagine which slot can be elongated. If you mean the inner mount of the lower wishbone, isn't this the aluminium subframe? I'll be replacing the subframe next month as the top wishbone is moving because of wear to the top mounts so I don't know if I should be opening up the holes at the bottom. Here's a jpeg of the assembly.
https://www.jaguarforums.com/forum/a...s-wishbone-jpg
The following 2 users liked this post by RaceDiagnostics:
Bill Swift (02-10-2014),
User 070620 (02-25-2014)
I don't like the idea much either RaceDiagnostics. I've actually just been trawling the internet for a new subframe, and if eccentric bolts on the lower arms aren't enough to compensate for the camber change bought about by the shorter springs I'll think again. But I can't see a 1" drop will make much difference and a little more camber won't hurt too much I don't imagine, as far as I know it's the tracking that you have to watch more with regards tyre wear.
#30
#32
Not normally, I do a rough check and if it's too far out I get the alignment done and shim it to how much it needs, Jaguar go up in .5mm increments but do not have a full stock so I now buy the thickest (8mm) and machine down to suit, the ironic thing is the thickest shim is also the cheapest
#33
#34
Thanks XKRacer. I've sourced a subframe on the internet and will make sure that eccentric bolts are at the front when I build it up, and I'll worry about the back if I need to once the alignment and camber have been checked.
Thank you everyone for your help. I'm feeling a lot more knowledgeable and confident about the job now.
#35
Hello again Mr XKRacer
My fingers been twitching above the 'buy now' button tonight, but your quote that 'you're more prone to just lowering the back' has stopped me.
Since you've mentioned about it being jacked up at the back I've been wondering whether to just do the back also.
What I'm wondering about your quote is whether by prone you mean prefer?
And as I'm trying to improve the suspension do you think that leaving the original soft standard front springs would okay?
Thanks a lot.
Thanks a lot.
scooternva
20
09-27-2023 11:25 AM
Guy-Pierre Boucher
09-16-2015 05:55 PM
