Has anyone ever changed the bulb on the roof switch
Hi
I'm trying to change the bulb on my roof switch. Jaguar XKR 2000 model, convertible of course.
I've removed the wooden gear lever surround with the switch on but underneath the bottom part of the switch is clipped into the plastic panel but surrounded by a metal bracket which looks very hard to remove without causing damage.
Just wondering if anyone has done this task.
Kind Regards
Rocky15
Kind Regards
Rocky15
Rocky15 (02-01-2016)
All managed to get sorted.
The worry I had was causing damaged by removing this metal bracket which was securing the switch in place but I managed to do it.
Apparently not all XKs have this metal surround, it's just extra protection for securing the switch. Jag must of had problems with the switch unclipping if pressed to hard.
Managed to remove switch, strip down and change the bulb.
