Has anyone tried to fit Nissan / Infinity lug nuts?
I got new tires for one of the XK8s today, and when I was reinstalling the wheels I noticed that a previous owner had installed "close enough" conical seat lugnuts. The wheels don't appear to be too damaged, but I see in seaching for the correct Mag style lug nuts, they have not gotten any less expensive since my last Jaguar. It looks like the norm is about $25 each.
However searching around for just Mag lug nut with the thread size, but NOT the term Jaguar turned up these for Infinity/ Nissan vehicles. They look like they should fit, and a set of 24 is less than 1 Jaguar nut. Available in black or chrome.
Received 3,266 Likes
motorcarman (06-11-2023)
Received 4,334 Likes
Later Jaguars might be able to use the Toyota / Lexus nuts. I ordered replacement lug nuts for a 2004 Lincoln LS to replace the ones on my old X-type. They looked identical, but only cost about $1 each.
I have read that, but have also read 12x1.25.
It seems very odd that Jaguar would use metric everything, EXCEPT lug / wheel nuts for years, on multiple vehicles. It seems more likely that 1/2"x 20 is close enough to seem like it fits. If you do the conversion it is 12.7mm x 1.27mm, slightly bigger diameter, and very close in thread pitch. Probably the larger diameter nut allows the slightly off thread pitch to fit. But stranger things have happened.
I will see if I can get a 12.x1.25 nut today to try on one of the studs.
Johnken (06-13-2023)
You are correct, both the original Jaguar nut, and whatever aftermarket conical nuts I have both fit a 1/2 x 20 stud better than the 12 x 1.25. They will run completely onto a 12 x 1.25 stud, but fit loosely.
I could not find a M12 x 1.25 nut on a Sunday to try on the car. Back to the drawing board.
Got a link?
All I am finding are the OEM nuts for $20 minimum - $400 to do the entire car,
Or used ones that are still very expensive for the condition they seem to be in, best price so far is about $70 to do the whole car.
Or conical nuts that don't work with the stock wheels, I already have a set of those.
Or Mag style nuts with a shank that is .75" or 1" far too long.
Or the White Knight brand I posted about for $25 per set of 20.
Here’s what I’ve got- bought on Amazon 2 years ago at $15 for four. However, looks like Amz doesn’t have them any more (and a search for these 73187SM 1/2” nuts returns results for incorrect 12mm with a slightly different model number ).
They still look great after 2 years. Not as cheap as the White knights, but no idea how they compare, longevity-wise.
Andy94SC (06-11-2023)
It seems that 73188sm is the same part. I see them in lots of 100 for a reasonable price, around $120. Summit Racing also appears to sell them individually for $1.99. They have a .50" shank length according to Summit.
The White Knight nuts arrived, and will not fit into the lug holes in the wheel. I got out my calipers and they measure .730" in diameter, just as specified. I measured my factory lug nuts, and they appear to be just under .700".
The Gorilla ones above appear to be the best bet so far, they speficify .690" diameter.
