Head and Connecting rod bolts
117 Views so far but no opinions. I don't like to see any question go unanswered on the forum so let's at least spark some discussion.
In the days of the straight 6 cylinder XK engine with cast iron block and aluminium head, it was regular practice to re-use cylinder head bolts once and put a 'pop' mark on the top of the hex to indicate they had been re-used.
I've gone through JEPC and the printed Workshop Manual for the early XK8 and found no guidance either to re-use or to replace head bolts on the all aluminium V8. My assumption for this is re-use is expected or there would be a warning that head bolts must be replaced.
I've always re-used con rod and main bolts for an overhaul unless there had been a failure.
1. Techs on the forum are likely to have seen any relevant TSB giving the definitive JLR guidance on re-use or replacement.
2. Parts specialists (check with forum Sponsors /Vendors) could say either 'we sell a lot of these' or 'rarely get asked for these'.
I'm off the don my Flame Suit.![Icon Lol](https://www.jaguarforums.com/forum/images/smilies/icon_lol.gif)
As a rule of thumb; Look at the torque spec for the actual bolt. If it is just a specific torque you can reuse it. If it is a specific torque and then a additional degree of turn (ex 90 Nm + 180 degrees) then you should not reuse it, as the actual torque is defined by stretching the bolt.
The following 4 users liked this post by NorXKR:
As were on the topic, here's the torque specifications for the 1999 X100 engine;
![](https://cimg9.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/677x1000/1999_xk8_torque_specs_f543f0866d93696c674c8d905a4def11e6d29003.jpg)
kstevusa (02-19-2022)
Received 2,390 Likes
The cylinder head procedure I attached to your previous thread contains the information regarding re-use of the head bolts and the torquing sequence. It states that they can be reused twice (step 26). I wouldn't, but ymmv.
The conrod bearing cap bolts are single-use. See attached procedure.
Engine Repair Course Code 168 (in the stickies) gives the bedplate reassembly instructions. The bolts are again single-use.
jagdohrman
07-09-2017 04:26 PM
