head rest adjustment
I just took delivery of my 2001 XK8. The only issue I have is with the headrests. As I understand it the middle button under the seat moves these. I have tried it. I get a noise, but don't see any movement of the headrest. Has anyone else had any issue here. I really don't need to move it up a lot...more need to move the headrest forward since I have to lean the seat back so much to fit into the cockpit at 6'4".
Grady
Grady
Look in the FAQ section under headrest repairs. In short, the plastic sheathing that holds the cable that adjusts the headrest needs to be shortened. There is a bunch of stuff including a good video by Rev Sam that shows the entire process. It is a pretty straightforward DIY.
Doug
Doug
Absolutely! If you track back through my earliest posts when I discovered I had the headrest problem on the driver's seat, you will see that most of my questions had to do with that first step of separating the fabric. I had tried the repair two or three times and gave up each time since I couldn't figure it out. Finally I tried one more time and accidentally stumbled on the method. The design is actually pretty brilliant and for quite a while I had thought that the fabric was physically sewn together. It is difficult to explain in words how to disconnect and then reconnect these pieces.
Doug
Doug
Doug
Nevermind. You're right. It is difficult to explain in words.
![Icon Confused](https://www.jaguarforums.com/forum/images/smilies/icon_confused.gif)
aholbro1
08-05-2021 05:02 AM
