Head unit type
I want to add Bluetooth. So the question is if there is an AUX input that is unused. Or if Alpine then I will consider theadapter that plugs in instead of the CD changer. I will have to order from abroad so taking it out just to look at the rear does not appeal as I want to use the car in the meantime meaning I have to put together and take apart a second time.
Hello Per,
That is an alpine unit, I have one in my XJR X300. It has no line in/AUX and I recently temporarily removed it to install an iSimple RadioMod unit which gives you Aux/line in by plugging into your aerial socket. It works quite well has allowed me to plug into the original stereo my Pure DAB/bluetooth/handsfree device which previously was transmitting via FM with poor sound quality. The sound is now much better quality. I preferred this to add unit to boot/trunk that might cancel out the CD-Changer and or require me to route a cable from the DAB/bluetooth unit in the front all the way back there.
Hope this helps,
Nick
Hope this helps,
Nick
Per, the connections on the back of your radio are round connections ( not square DIN type connections). If you want an all inclusive bluetooth module, this one below might be the one. I have not installed this one ( I did the Motorola T605), but this certainly looks like it would work.
https://www.discountcarstereo.com/a2diy-jag97cd.html
