Header Panel Removal Above Convertible Latch
![Post](https://www.jaguarforums.com/forum/images/icons/icon1.gif)
Attempting to remove Header Panel atop convertible windshield to inspect hydraulic hoses and latch assembly. Removed two screws and two plastic push pins at top of A pillar; however header panel WILL NOT come off easily. Do not want to use too much force for fear of bending panel. Just installed pressure relief valve in trunk and want to inspect hoses and latch. Any special secrets? 2001 XKR
That is because there are actually 4 screws. There are two more screws hidden at the very ends of the header, beyond the push pins. They are actually under the weatherstripping, and there is probably a little excess adhesive over them also. The ends of the weatherstrip have to be very gently peeled back to see them. On an older vehicle you might tear the weatherstrip slightly doing this, just be as gentle as possible. A small slit can be repaired with a dab of weatherstrip adhesive.
BTW, by removing the outside top header, FYI, you will just have a narrow window to view the hoses. If you want full access, the fabric header inside the car must be removed.
The black sheathing has some deterioration (appears to be age cracks, possibly heat); however, the white webbing around the hose appears OK. Lithium on latch. Since I just installed the pressure relief valve as a preventative measure, I would rather not tackle the replacement hose process, even though the hoses are Nylaflow hoses. (Penny wise, pound foolish?). By the way, those two extra screws under the weatherstripping are sure fun to put back - #*%*@!
99xk8guy
06-05-2023 06:28 AM
Aus V8S
11-13-2015 11:01 AM
