Headlamp Adjustment
Headlamp Adjustment
For reasons which have much to do with a minor collision with a deer a few weeks ago, I have had to remove and replace my front bumper (fender ?) and headlamps.
I can't find anything in JTIS about how to check and adjust the alignment after putting the lights back.
There are two things that turn - the large knob on the rear of the motor which raises and lowers the dip beam, and the smaller white plastic rod - see arrows on photograph.
Can anyone point me to the correct bit of JTIS, or somewhere with instructions on how it is done.
Many thanks,
David.
Many thanks,
David.
Headlamp adjustment
Sorry to hear about your encounter with a deer...
My 97XK8 does not have the motorized front headlamp adjuster as yours, but I would still like to hear from esteemed members on this forum as to how to adjust my headlamps
Many thanks,
David.
Many thanks,
David.
Gosh that's funny I've been meaning to do the same thing too. I didn't even know there were motorized ones for 1997 and/or 1998. I look forward to the instructions as well. I was just thinking about this last night when I turned off the fog lights - my low beams alone are barely useful. It will be nice to get them right.
So, if anyone knows how to do this, please chime in and thanks.
John
John
.......... I have had to remove and replace my front bumper (fender ?) and headlamps.
Can anyone point me to the correct bit of JTIS, or somewhere with instructions on how it is done. .......
I believe the 'fender' is the wing. Best to avoid any attempt at the American automobile lexicon. Before you know it you'd be involved with 'trunks' (part of a elephant) or 'hoods' (dubious characters from Chicago or NY).
I also can't find any reference to headlamp adjustment procedure on the 4.0 litre models in JTIS.
The adjuster is the round black knob. I think the white/knob/rod is for the headlamp level rotary switch in the centre console.
This should be set to position '0' when aligning the headlamps.
MsMaybe98 (05-29-2021)
As with all things Jaguar, I think it's quite complicated - I'm still looking for information, but so far seems like ..........
Some cars, right from 1996/7, have a manually adjusted levelling mechanism - these are identified by a "bubble level" and a sort-off slotted adjustment bracket under the clear plastic cover on top of the light unit. There are two little white 7mm (??) plastic hexagon nuts like the one in my photograph to set horizontal and vertical position. Paul Pavlik has a post on roadfly.com with the detailed instructions -
headlight assembly adjustment
This seems to apply to US cars - can someone confirm or not whether there's a dash operated knob for headlight adjustment on these cars as in Graham's post - if there is, I can't see how it can work as there doesn't seem to be any electrical connection and I can't think it's mechanical.
On my car (1997) - maybe all UK cars ?? - there's an actuator motor on the back of the lamp unit with a separate three pin connector. Inside is an electric motor and quite a complicated printed circuit board (I just took one to bits !!)
I think you set the level (with headlights on) using the big black knob, and then when you switch off, the headlights automatically lower. The little knob on the dashboard gives "fine tuning" to this default setting depending on loading in the car.
The other knob (little white one) is, I suspect, for horizontal adjustment, but I need to verify that by trial and error.
My car has "retrofit" HID bulbs, but I have always assumed that the headlight unit is the original 1997 Jaguar installed kit.
Will keep looking.
Will keep looking.
........ I think you set the level (with headlights on) using the big black knob, and then when you switch off, the headlights automatically lower. ...... My car has "retrofit" HID bulbs, but I have always assumed that the headlight unit is the original 1997 Jaguar installed kit.
Will keep looking.
Will keep looking.
My 2005 XK8 had HID's with 'self levelling'. The beam would rise when the ignition was switched on and lower when it was switched off.
It sounds like you may have a PO hybrid.
Graham.
Confusing isn't it ??
What I can't work out is .............. on my 1997 wiring diagram, it shows a separate circuit, on a separate page, for "self levelling cars" which is the "centre console switch pack" (dashboard knob) and the actuator motor on each headlight unit. Nowhere in any of the other diagrams in the same 1997 wiring guide is there a schematic for a car without the actuator, but *with* the console switchpack.
Here's my guess - please contradict if you know different and maybe we can end up with a definitive answer - or maybe I need to get out more ....................... :-)
For legal or other reasons :
US cars (and other parts of the world) were fitted with "ordinary" halogen bulbs in "ordinary" metal reflectors for both main and dip beams. These are adjusted manually as in Paul's roadfly thread, and have no centre console adjustment knob.
There may have been an option to "upgrade" to ................
UK cars were *either* as above, *or* were fitted, on dipped beam, with "ordinary" halogen bulbs but with a "projector type" lens for better performance. Regulations dictated that these MUST have a self-levelling mechanism. They also have the centre console switch.
It is easy to retrofit HID bulbs to these types of reflector, but they are, at least in theory, illegal on mine because I do not have headlight washers which I believe are mandatory on HID headlights in the UK. Main beam (OEM) is "normal" halogen bulb as with US cars.
Photos show inside of actuator :
David,
According to the Parts Catalogue, Canada/USA XK8 headlamps are different from RoW (Rest of World). I've posted only non powerwash here as that it your type:
1. Canada & USA
2. except Canada & USA
Within this category, Japan has yet another specification.
Although interesting, I don't think it's going to help resolve the mystery of your setup!
1. Canada & USA
Graham.
But it does .................. mine is exactly as in the second diagram except that a previous owner has changed 6 & 9 (the dipped bulb and holder) to a HID Xenon set up with external ballast etc. I guess because of different regulations in different countries, there are numerous (US, Canada, Japan, UK, Europe ?) different headlamps. US / Canada cars don't have the actuator and self-levelling "by default".
The only thing it doesn't explain is your 2001 car and maybe other years / models which would seem to have the console levelling knob, but no external actuator as in my photographs. Maybe there's a much smaller motor inside the light unit, but it doesn't show on any wiring diagram I can find.
Anyway, I think I know how to set mine now - for anyone in US / Canada - use Paul Pavliks post (link above) for full instructions on how it's done on your cars.
Cheers,
David.
Cheers,
David.
Headlamp Leveling Actuator JLM12117 Internals
If anyone is interested how those actuators work and how their internal components may be repaired - attachment has circuit diagram, component lists and PCB component layout.
These actuators are only on European cars and I could not find part near me so I reverse engineered content to be able to fix electrics - (one circuit board connection was bad - in visible to eye).
Depending of position of leveling switch in center console CTRL input voltage to actuator varies between 8 and 11 Volts - and actuator changes postion accordingly.
Br, tlindi
Br, tlindi
Graham.
Attachment 115722
Attachment 115723
Attachment 115722
Attachment 115723
Last edited by tlindi; 05-28-2021 at 09:00 AM. Reason: Revised attachment updated - yet again
Headlamp adjustment
Park on level surface. Check with level on open door door sill.
Pull the plastic access panel off (hood open to service position look for panels above headlight area). This is the panel you would pull to replace high beam bulb.
See tiny bubble level inside on headlight housing.
Turn white plastic adjustment pieces to get bubble in level centered. As I recall a tiny ratchet makes this easy.
John
John
Blown Headlight Levelling fuse...
Hope I'm on the right thread here, but looking for some help if possible! My 2002 XK8 failed its MOT yesterday on 2 counts. Firstly the rear fog lamp 'tell tale' doesn't light up when the fog lights are on. Is that a simple (?) switch/bulb replacement?
Secondly the headlight levelling didn't work on either headlight. When I got home, I checked the fuses and the Headlight Levelling Fuse (F3) was blown. I replaced it and started the engine. Pretty much immediately I was aware of some smoke coming from under the bonnet coupled with a pretty unpleasant 'burning' smell. I turned the engine off and opened the bonnet. I couldn't discern where the smoke and smell came from but the fuse had blown again! I'm pretty sure that I've never adjusted the headlight levelling switch but either way, I'm a little scuppered in terms of getting a new MOT before I get this sorted. I've watched a few YouTube videos of people accessing the headlights etc. and it looks a pretty onerous process, but before I do anything, has anyone got any ideas as to what might be happening here? It passed the MOT with no problem last year and as I said, I've never adjusted the switch! What could be casing the burning smell and the smoke? Any assistance is appreciated!
