headlamps
headlamps
Finally the car is repaired with a lot of second hand parts and is ready to go for technical inspection.
When adjusting the headlamps we found the left lamp not be able to allign for a european car. The lamp looks to be an english version.
So before we take the lamp out we would like to no know if there is a adjustment on the lamp to make it european or I need to replace the headlamp again?
Bleujag (06-24-2014)
Luc,
The RHD/LHD plates have exactly the same fixing holes so that should be the simplest solution.
Here's a thread from Europe Region forum about headlamp conversion on imported XK8's to pass the French CoC that may be of interest:
https://www.jaguarforums.com/forum/x...-change-68469/
rentzoo
11-10-2015 04:56 PM
