Headlight assembly question
Is there a procedure to remove the whole mechanism covered by the grey cover you circled in yellow? Further digging into this I see that the tip end of the mechanism that plugs into the white plastic plunger, you marked with the red box, is broken off. Someone tried to glue in place. I am thinking If I can remove the whole mechanism I may can repair the broken tip and plug it back into the white plastic plunger. Or hopefully find a replacement mechanism.
I don't know, but there must be.
for all your wiring questions
JagRepair.com - Jaguar Repair Information Resource
Bill Jacobs (07-28-2024)
Thanks Pistnbroke while that detail is very good it is above my comfort zone. I think I would rather attack this from the actual ground spots to see if they or it might be source of my problem and just need to be cleaned up. Any idea from anyone (picture preferably) when the HID headlight ground location(s) are? I found photos for XKJ and other Jags but none for XK8.
In advance thanks,
Bill
In advance thanks,
Bill
