Headlight assembly question
Old 03-06-2024, 06:17 AM
giandanielxk8's Avatar
Received 1,442 Likes on 772 Posts
Originally Posted by Bill Jacobs
Is there a procedure to remove the whole mechanism covered by the grey cover you circled in yellow? Further digging into this I see that the tip end of the mechanism that plugs into the white plastic plunger, you marked with the red box, is broken off. Someone tried to glue in place. I am thinking If I can remove the whole mechanism I may can repair the broken tip and plug it back into the white plastic plunger. Or hopefully find a replacement mechanism.
I don't know, but there must be.
Old 07-27-2024, 09:19 AM
Bill Jacobs's Avatar
Still struggling with my headlight issues but now the passenger light has gone out. Someone suggested a possible issue with the ground connection as it can be an issue. Anyone have an idea where the ground for the HID lights for a 2004 XK8 is located?
Thanks,
Bill
Old 07-27-2024, 10:25 AM
Pistnbroke's Avatar
Just put in a new earth wire and forget the old one
Old 07-27-2024, 11:45 AM
Sounds good but what wire (color or location) do I ground?
Old 07-28-2024, 02:12 AM
Pistnbroke's Avatar
for all your wiring questions
JagRepair.com - Jaguar Repair Information Resource
Bill Jacobs (07-28-2024)
Old 07-28-2024, 09:47 AM
Thanks Pistnbroke while that detail is very good it is above my comfort zone. I think I would rather attack this from the actual ground spots to see if they or it might be source of my problem and just need to be cleaned up. Any idea from anyone (picture preferably) when the HID headlight ground location(s) are? I found photos for XKJ and other Jags but none for XK8.
In advance thanks,
Bill
Old 07-29-2024, 02:04 AM
Pistnbroke's Avatar
You only need to know the colour of the earth wire from the diagram I sent you and then scotchlock a new wire onto it and earth the other end .
PS the larger bolts under the hood are live not earth !!!
malc4d
01-22-2024 08:32 AM
placer61
11-01-2023 03:04 AM
carelm
10-06-2009 01:16 PM
Quick Reply: Headlight assembly question
