Headlight jet washer cover replacement - RESOLVED
I just got the replacement cover for my broken right side washer cover on my 2001 xkr convertible. Does anyone
know what it takes to change them out? Thought I would ask before I break something.
Last edited by GGG; 08-16-2018 at 02:05 AM. Reason: Add "RESOLVED" to thread title
You need to start to remove the headlight. Before you try that though there is a tip on here https://www.jaguarforum.com/showthre...=1#post1023627 it simply shows the nut you have to remove to get the headlight out. Hopefully, like the link, yours is missing too. Its then just a case of disconnecting the wiring, red connector at front. The U connector slides sideways and the plug disconnects, look for the two slots on the side to see which way it goes. Two screws. Then pull/jiggle the headlight forward. The washer bit is the most awkward bit. It fits underneath in a V shaped grove. You dont need to remove the headlight but if you do this photo will show you its separate https://www.jaguarforum.com/showthre...=1#post1024714
The following 2 users liked this post by frankc:
Lovemykitty (08-15-2018),
Orthodixie (08-15-2018)
Frank,
I haven't had to replace the cover so I'll ask the dumb question.
Isn't it possible to have an assistant operate the headlamp washers and then hold the one to be repaired in the extended position whilst you fit the new cover?
Received 2,193 Likes
The following 2 users liked this post by Brutal:
Johnken (08-15-2018),
Found it! I knew I had done sort of a how to https://www.jaguarforum.com/showthre...=1#post1080771
Hope it helps.
Hope it helps.
Just spotted this. Do you want to replace the chrome cover or the headlamp washer? I thought you wanted to replace the whole washer system. (my fault) If I remember right the cover just snaps on and off. The headlamp washers do not operate every time. I think its about every 8 or 9 pulls of the windscreen wash. If its just your cover that is is missing I would think the new one should just push on. Just take a look at the lugs behind the new one. My cover came off when I did the headlamp I think I just pushed it back on.
WOW how easy was THAT!!!? the old one popped off as I was trying to manually extend the washer jet. I used just a teeny swipe of vasoline
on the receptive area on back of the new one and it popped right on. Sure all my fixes were that easy. Many thanks to all of you who responded to my posts about this.
GGG (08-16-2018)
I am looking for a left hand front headlight washer jet cover. Do you still have one I could buy?
Gordon
w1ldcard
07-17-2013 11:26 AM
