Headlight lense removal
This thread should help you remove the headlight assembly:
https://www.jaguarforums.com/forum/s...ight=headlight
Once it is out, gently pry up the tabs separating the lens housing and the body of the headlight (I think there are 2 or 3 on each long side and one on each end). The lens and the housing will then separate, it will be helped automatically by the rubber gasket pressure. Replace the lens with the new gasket it comes with.
1964Daimler
09-09-2015 11:28 AM
