Headlight Washer
Received 2,194 Likes
if you pull out the washer, youll find that 1 or both of the nozzles popped out and now you need to replace the assembly....
And no youre not the only 1 to laugh Black, I find the only thing theyre good for is messing up a clean car when all you want to do is clean off the windshirld alittle
"I find the only thing they're good for is messing up a clean car when all you want to do is clean off the windshield a little"
When I first got the Jag, I thought "How cool!". Now, I dread them coming on and find them totally unnecessary, at least for my driving location. Eventually I'll probably remove a fuse or something to stop them from messing with my wax jobs....
Brian
Brian
berniekiwi (09-01-2022)
I discovered that my headlight washers are activated every sixth time you push the washer button. Not sure why this is. Guess I have the RTFM too! Lol!
How did I discover this? I was rolling around on the ground laughing too when they come out and wanted to see it again. LMAO! I have an S type mind you so don't know if there is a difference between types.
Cheers!
Rob
Cheers!
Rob
Headlamp Washers...
Thanks for the advice and confirmation of what I also thought was a design short-coming!
Although they did not make me laugh when I first saw them operate, I did find them useless. That being said (although I like everything to work...I'm funny that way) now that they do not work, they are not effective, mess up the newly waxed hood and its not an easy fix, I may just let them be.
