Headlight washer
Old 01-24-2012, 06:24 PM
LedZepplin's Avatar
Default Headlight washer
My LH side headlight washer spat out one of the nozzles so it now gushes water all over the bonnet (hood). XKR 2001
How do you get the washer to pop out? so that I can replace the nozzle assuming thats the problem. I assume this can be done without taking the headlight out.
I've checked all the threads but no one actually describes how to get them to just pop out? Do you just pull them, if so how as the glass looks like it will break or pop off if you do that.
I may just remove the 30amp fuse as I live in CA so rain is like 3 times a year and my car is never out when it rains LOL
Simon
Old 01-24-2012, 06:48 PM
The Coupe's Avatar
Simon
I don't have the headlight washers on my car, but if I did, I would definitely pull the fuse and de-activate them. Most who have them consider them to be a) worthless, and b) a pain in the butt.
Old 01-24-2012, 07:20 PM
Skid Mark's Avatar
Another example of over engineering by Jaguar. I put the powerwashers in the same catagory as the articulating cup holder, power headrests, interior mirror mount (and mirror) and oil cooler.
GGG is offline
Received 16,861 Likes on 12,186 Posts
...........How do you get the washer to pop out? so that I can replace the nozzle assuming thats the problem. I assume this can be done without taking the headlight out.........Simon
Simon,
Its clipped into the headlamp housing:
XK8 - Headlamp Washer.pdf
Removing the fuse seems the simplest option.
File Type: pdf
Old 01-24-2012, 11:30 PM
XKRacer's Avatar
Its a headlight out job, or at least released so you can tilt it up
Old 01-25-2012, 12:12 AM
H20boy's Avatar
Received 1,151 Likes on 753 Posts
There's a big thread about that washer, can't remember who was asking, and pursuing the same repair. First thing that comes to mind is the max headrom (sp) profile avatar...but I could be high on something. I'd search the forum for you, but i'm getting a little woozy
Old 01-25-2012, 02:18 AM
GGG is offline
Simon,
SORRY - I posted the wrong attachment earlier.
It should have been 'XK8 - Headlamp Washer.PDF'. Here's the right one.
It has the removal procedure and an illustration of the washer unit fixings.
Old 01-25-2012, 05:34 AM
dennisw's Avatar
I used mine once to see if they work..what about back seats.. sun glasses box...
Old 01-25-2012, 05:48 AM
GGG is offline
Are headlamp washers separately switched on the 4.0 cars?
Mine are automatic. The first time the screen wash/wipe button is pressed and every sixth press thereafter. There isn't an option to omit the headlamp wash.
Old 01-25-2012, 07:18 AM
dennisw's Avatar
mine are the same aslong as your lights are are on they work every third press of the washers
Old 01-25-2012, 07:40 AM
GGG is offline
Shame they didn't concentrate on solving the moisture inside the headlamps before working on squirting more on the outside. Drilling a hole in the side as a TSB smacks of desparation and still doesn't cure it.
Old 01-25-2012, 08:37 AM
LedZepplin's Avatar
Wow this is an emotional issue LOL OK going to take the headlight out and have a look to see whats up. Only doing this cos you guys find this such an emotional issue + have nothing else broken on the car at the moment.
Simon
Old 01-25-2012, 09:10 AM
dennisw's Avatar
never had that
Old 01-25-2012, 06:12 PM
LedZepplin's Avatar
Default Headlight washer nozzel
OK took a looks and my highlight washer is missing one of the nozzels. anyone any idea where I can get one at a reasonable price ?
Old 01-26-2012, 02:39 AM
GGG is offline
Simon,
The Parts Manual shows the nozzles aren't available from Jaguar as a separate component:
The Powerwash Jet (item 1 in the attached JPG) is also listed as 'left' and 'right' under different part numbers.
Had a look on eBay and the few Jets listed are in the £30 - £60 range which suggests the cost from Jaguar will not come under the heading of 'reasonable'.
Old 01-27-2012, 08:46 PM
LedZepplin's Avatar
Simon,
Attachment 16390
Ok thanks I made one from the top of a make-up eye liner pen. Dont think the gf will notice its missing LOL
Old 02-01-2012, 07:16 AM
mikeeadyjr's Avatar
Angry
...and the heating system
Old 02-01-2012, 11:08 AM
jamjax's Avatar
Simon;
I love the MacGyver fix with the eye liner pen.
What's next, her pantyhose for an emergency fan belt?
Mike junior;
What do you need a heater for in El Paso?
Maybe two days a year?
Two feet of snow here and the heater works fine, even with the top down.
The headlamp washers are brilliant for getting the snow and salt off of them.
cheers,
jj
2002XK8Orlando's Avatar
I have one missing as well...looks like I need to check this option out
Old 02-01-2012, 11:06 PM
Jag Pilot's Avatar
Simon,
Attachment 16375
Shall we assume from step #7 on page 2 of the referenced pdf that the entire headlight housing assembly can be withdrawn rearward into the open fender area? I have wanted to remove mine to clean up the interior of the lens and housing.
Quick Reply: Headlight washer
