Headlights always on
Old 04-24-2016, 11:23 AM
Jandreu's Avatar
Another route is to simply add a jumper in the left hand engine compartment fuse box for the fog lights to be on at all times.
See here post 12 for full details https://www.jaguarforums.com/forum/x...s-03-a-123769/
Old 04-24-2016, 07:38 PM
Jan_H's Avatar
Hi John,
Thanks for the info. At the moment I will just continue to use the 'auxiliary' relay I installed for the DRL function - it does the job. The other headlight settings appear to work OK, so this repair is now on the to-do list!
Jan
Old 04-25-2016, 04:34 PM
Jan_H's Avatar
Car passed the RIV inspection......excellent!
For others dealing with the Daytime Running Light issue on US cars imported into Canada, the requirement for these is:
"This Vehicle requires daytime running lights [DRL] to comply with CMVSS 108. The Master Headlight switch must be in the OFF position in order to pass DRL verification."
However, these lights don't need to be the headlights - they can be fog lamps (which I used, since I think this actually looks best), or apparently even 'add-on' spot lamps or LED strips.
Jan
Old 04-25-2016, 04:38 PM
Jan_H's Avatar
Default Daytime Running Lights
Jan
agentorange
04-16-2022 09:04 PM
blindside
02-12-2016 02:20 PM
sadepol01
02-11-2016 08:22 PM
cacamp
02-11-2016 08:22 PM
rhscare
02-11-2016 01:03 AM
Quick Reply: Headlights always on
