Headlights Failing when indicating left....
![Question](https://www.jaguarforums.com/forum/images/icons/icon5.gif)
I think it might be a fault in the switch stalk, or a connection fault.
Main Beam wont work (main and dipped switch off) but the Main Beam flash works
On left indicator Main Beam and Dipped fail/switch off
On Right indicator Dipped Beam returns.
This is pristine 98 XK8, low mileage, stored dry UK Model
Anybody seen the same problem?
Can anyone give me a workshop manual section on removal/refit of indicator/light switch stalk?
Is there a problem area in light connections that might be causing this problem?
Regards
Andrew
Regards
Andrew
