headlights, windshield, Radio
Radio ticks - did you change your ignition wires? As I recall some models without RF supression can cause this. On other cars, some have had sucess grounding the hood to the chassis (effectively turning it into a shield), but an ohmeter can tell you if it is grounded before you even consider this. I am brainstorming on this one, do a google on cars AM radio interference supression and see what you get. When you mention the windows - does it show only when wearing polarized sun glasses? I have to ask because that can explain it.
Here's a thread on moisture in the headlights. Post #18 even has Jag TSBs.
https://www.jaguarforums.com/forum/x...adlights-1316/
Other threads exist if this doesn't help. Just search for moisture condensation headlights. It's a common enough problem.
kelliott (05-21-2014)
Thanks for the info. The windshield is the same day or night it looks like threads running through the glass. It almost looks like a car cover was on the car for a protracted amount of time and left an imprint. I've tried to clean the windshield and it makes no difference.
CaneCounsel007
11-13-2015 09:05 PM
al_roethlisberger
09-21-2015 08:15 PM
1964Daimler
09-09-2015 11:28 AM
