Headliner replacement
Hey Everyone,
I was wondering if anyone has had to replace their headliner and if so what material/brand did you use to match it to the sun visors.
I am looking to do alcantara or synthetic alcantara as I hate the stock gray they used on the car, it looks cheap in my mind.
I also should mention I have a gray headliner which I believe came in most XKR's back then.
Thanks for your input
I had to replace the headliner in my 2004 XKR. There was a significant droop above the passenger seat and the fabric on both A pillars was loose. I considered, read and researched on doing it myself, but finally decided to let the pros handle this task. Took the car to a British car restoration shop in Waynesboro VA. So, I can't answer your question regarding fabric type, but, if you choose the route I took, it will cost about $400. It turned out perfectly and, in my opinion, it was money well spent.
JaguarXKR (06-03-2016)
Some very useful advice here:
https://www.jaguarforums.com/forum/x...learned-70845/
Although this aftermarket supplier won't be much use to you, it may be of interest to UK members:
Jaguar XK8 replacement headliner board - Jag Headlinings
