Headrest cable fix - cables made XK8 Coupe
Big thanks to member chopr for the idea of replacing the cable rather than shortening the sleeves. And thanks for the specifications.
I ordered an extra pair of custom cables. $40USD for the first member that wants the pair. Private Message me.
A couple of tips.
1. Test the switch to see if the motor works first (if it doesn't work then you may have a blown fuse or a bad motor)
2. You don't have to remove the seat. Just move the seat forwards and tilt the back forwards
3. For the screws attaching the plate that holds the cable to the motor. Only loosen the back torx screw and remove the front screw. You'll need a T25 torx for the screws and a pair of pliers for the two clips that hold the straps underneath the seat.
4. I recommend you have a 1/4" ratchet, 4 inch extension, and Universal joint. that will help you get the screw out.
5. You don't have to pull the seat cover up all the way. Half way should do it for you.
6. After you pull the particle board stiffener out there are plastic clips along the edges. Push them inwards to release them from the metal frame.
7. When you pull the cover up do not pull on the foam bolster. Just the seat back cover.
A couple of tips.
samson2 (01-17-2016)
