Headrest fix
Old 10-09-2016, 10:04 AM
Brian XK8's Avatar
Default Headrest fix
I spent yesterday afternoon doing the headrest fix. After reviewing YouTube, I felt confident that I understood the process and the job wasn't tough. It took about an hour and half to do the passenger seat and after the learning curve, a bit less than an hour to do the drivers seat.
I didn't cut the sheave in the middle and use heat shrink as the TSB suggests. Rather I cut the sheave immediately above the metal fitting that fits into the motor. Using a drifting tool to remove the waste sheave, (which was a little longer than the recommended 12mm, but not by much) I then re-fitted the metal fitting to the end of the shortened sheave and reassembled the seat. There is no risk of heat shrink not holding so, hopefully, the repair won't fail.
I suspect it will take me longer to clean up all the fine dust that was released by stripping the leather seat cover back than it did to affect the repair!
Old 10-09-2016, 11:23 AM
andyzeg's Avatar
Well Done Brian! I did almost exactly the same as you last year with my passenger seat and it has worked perfectly ever since.
One day...we'll get these cars right!! HaHa!
Take care
Brian XK8 (10-09-2016)
carzaddict
09-19-2023 11:09 AM
bcucharternet
10-30-2019 10:04 PM
Brandon Wright
09-01-2016 10:26 PM
vdpnyc
08-26-2016 12:51 PM
webshark
08-24-2016 02:17 PM
Quick Reply: Headrest fix
