Headrest goes up in steps
Hello, just wanted to know if someone had similar problem with headrest as shown in the video:
After I fixed the common and known problem with cable, both headrests started to work. However this one (passanger side) goes up only when pressing button on the seat repeatedly. And it also does not retract when pressing recline seat button. Could the motor be worn? I had the similar issue with steering column tilting. I had to repeatedly press the button it in order to adjust it. After changing the motor (part nr. JLM12186) it started to work as usual.
Thank you.
Facebook Post
Thank you.
