Headrest Repair Instructions (Video)
Old 06-06-2017, 12:37 PM
chopr's Avatar
Default Simplest, most permanent fix...
Most of this discussion seems to be how to reattach the cut sheath to keep it from separating later. Make it easy on yourselves... get a speedo shop to make a cable 18 3/4" long and slip it into the housing. Done. Forever.
  #62
Old 05-17-2021, 10:53 AM
cgaechief's Avatar
Found this while researching the issue this morning. Seems like the best solution to date.
  #63
Old 05-17-2021, 01:36 PM
cgaechief's Avatar
Default FINISHED!
https://www.youtube.com/watch?v=8lcA_b2aCFg
FINISHED!
I just completed both sides. From the time I posted this last post and this one I did both headrests. No heatshrink. I did just like this chap showed, except I put a dab of gorilla glue in each end before I pinched it just for good measure. I would have been done a lot sooner if I had figured out that bottom upholstery fitting sooner. When I got to the second side I laid bottom piece flat against the board and the folded the upper seatback piece under and it just snapped into place super easy. I think it took 2 hours total; getting tools, doing the work, putting tools away and then vacuuming up the dried up crusty old foam bits.
I think this fix is a done deal and won't have to be done again.
H20boy
07-23-2021 09:39 PM
Jaguar Forums Editor
Jaguar Press release
09-30-2020 06:53 AM
millertic
09-20-2015 10:14 PM
09-14-2015 11:18 PM
09-04-2015 09:18 AM
Quick Reply: Headrest Repair Instructions (Video)
