Headrest Shrink Tubing alternative
Howdy Folks:
While attempting the headrest cable fix, I discovered that the shrink tubing fix had already been done (probably by a Jaguar dealer) but had pulled apart over time to the point that it was inoperative. Not wanting this to happen again, I tried to figure out some other way to fix it. What I came up with was this:
Two pieces of 3/8 ID 1/16 wall Tygon clear tubing 1-1/2 in long silt longways one over the other with the seams 180 deg apart. Clamped with (2) 7/32-5/8 hose clamps.
It works for me, just thought I would pass it on.
Received 2,192 Likes
Max torque 10 in-lb
working torque 5-7 in-lb
What I did:
20 in-lb on the headrest fix (just an educated guess at the time)
Now out of curosity:
Bench tested another clamp which passed at 25 in-lb but failed (stripped)at 30 in-lb
Concluding that the clamp will probably fail before the housing crushes into the drive cable.
If I had it to do over, I would torque to 10 in-lb.
I do not know of any local clubs but I have been invited to Cars and Coffee at the Lake which you may have seen posted in the "South US" forum. Although I would like to go, to date, I just have not been able to attend. Maybe there would be interest on this forum to run the Blue Ridge Parkway this fall.
