heat not working. blows cold
My prior car, an '01 XK8, had something similar.
Every now and then, mostly on the 1st call for heat in the Fall after a summer with no use, it delivered only cold air.
By trial end error ... setting the temp control to max and letting it run there for a few minutes made heat, and then the temp control could be set where I wanted it. No idea why this worked, but there it is.
Check the heater pump fuse (#15, 10 Amps) in the fusebox under the hood on the driver's side.
If that is OK you might also try swapping the relays in the fusebox.
If still no luck, either:
-Your heater pump has failed
-Your heater core is clogged
-Your heater valve has failed
-The electronic controls have failed.
The heater pump is most common, but coolant types were ever mixed in this vehicle a clogged heater core could be a likely result. The valves do also stick occasionally.
Plenty of info on most of these repairs on the forum.
jazzman20014
10-26-2015 04:15 PM
Poet
10-06-2015 09:40 PM
jagent
09-12-2015 09:10 AM
