Heated Seats
![Red face](https://www.jaguarforums.com/forum/images/icons/icon11.gif)
Ladies and Gentlemen,
I own a 1999 XK8 convertible.
The passenger's side heated seat is not working, and I cannot find a specific fuse connected to the operation of the heated feature..
Any one can enlightened me on what may cause thew problem ? fuse ? switch gear ?
Many thanks,
ckt
Many thanks,
ckt
Hi CKT,
There are several threads dealing with this - I've done some research since I also have te same problem. But it's low on my list at the moment.
Anyway, short answer is that there is no fuse - the heater is powered direct from the Seat control module under the seat.
To get you started, here's a link to a thread I found useful: https://www.jaguarforums.com/forum/showthread.php?t=82568
Good luck
Good luck
When I had this issue on my 2005 XK8, it turned out to be a cracked track on the Seat Module circuit board. Bridging the gap with solder fixed it.
When you get a minute, please follow this link New Member Area - Intro a MUST - Jaguar Forums - Jaguar Enthusiasts Forum to the New Member Area - Intro a MUST forum and post some info about yourself and your vehicle for all members to see. In return you'll get a proper welcome and some useful advice about posting to the forum.
Hi CKT,
Good luck
Good luck
Hi CKT,
Good luck
Good luck
42Ajd
12-30-2015 09:45 AM
FS[LowerAtlantic]: 2007 S-Type $.2 For Sale
captbob73
10-24-2015 05:49 PM
Poet
10-06-2015 09:40 PM
adam699
09-12-2015 05:32 PM
jagent
09-12-2015 09:10 AM
