Heater core flush - which pipe is in vs out
Received 2,397 Likes
See the attached pdf. It is taken from the 2nd edition (1999) workshop manual, but it is the same.
Check out also this post from fmertz:
https://www.jaguarforums.com/forum/x...2/#post2118558
The following 2 users liked this post by michaelh:
JimmyL (11-15-2021),
Silver2002XKR (11-14-2021)
Once I got the little black plastic coolant fill tank and its bracket out of the way it was a lot easier to see what was going on, and the pipe on the right was clearly connected to the heater pump (so that was the heater core inlet, and the one on the left was the heater core outlet.) I flushed it backwards, forwards, backwards, forwards, then backwards, at which point it was allowing a healthy stream of water through. Put it all back together and now I have heat, just in time for top-down-heater-on driving season in Arizona! :-)
Lawrence Watkins
12-10-2022 08:52 AM
Corndonkey
22
12-11-2020 03:42 PM
Lawrence Watkins
08-05-2019 07:26 AM
