Heater hose from engine connection
Old 04-16-2016, 02:57 PM
BobRoy's Avatar
Default Heater hose from engine connection
Removing engine from 99 xk8. I'm having trouble getting the heater hose from the engine to disconnect. I don't want to break it by doing something wrong.
Old 04-16-2016, 05:25 PM
brgjag's Avatar
You need to be a bit more specific. Hose connected where? Details man.
Old 04-16-2016, 05:44 PM
BobRoy's Avatar
It's the heater feed hose from the engine. It's on the right side( passenger) at the rear of the engine below and to the right of the TB. I believe it is called a R slip connector. I'm not with the car now so I can't send a picture. I found a picture of it in the manual but couldn't find any place showing how to disconnect it. Sorry for the poor description but i'm not the best at typing. I went to school in California.
Old 04-16-2016, 06:13 PM
Rick L's Avatar
I believe you are talking about the Norma connectors. Do a search on Norma and you will see that they are problematic to get apart, but there are about a dozen workarounds. Good luck
BobRoy (04-17-2016)
Old 04-16-2016, 06:24 PM
BobRoy's Avatar
Thanks for the response I'll check it out
Old 04-17-2016, 09:51 AM
BobRoy's Avatar
Thanks to Rick letting me know it was called a Norma connector I was able to find ways to get it off. I was able to slide the collar back but it still didn't release. I used a little persuaton with a screwdriver and hammer and with a couple of taps it came off without damaging the connector. I wasn't crazy about the other alternative to cut it off and use hose clamps.
Old 04-17-2016, 10:00 AM
Rick L's Avatar
Glad to hear it. This forum is truly amazing.
Old 04-17-2016, 10:22 AM
BobRoy's Avatar
If it wasn't for all the imformation and the help from its members I wouldn't even be dealing with Jaguars. But now I find it an enjoyable hobby. Thanks again.
Old 04-17-2016, 08:09 PM
brgjag's Avatar
why would a good old fashion hose clamp work there instead of the fancy *** connector??
Old 04-18-2016, 11:57 AM
BobRoy's Avatar
https://www.jaguarforums.com/forum/x...rma+connectors
This is a link to the thread I used. Some threads mentioned that they broke the connectoror or just cut it off because they couldn't get it apart. This thread shows how someone used a piece of hose to repair the connection. If I can I like to keep things original.
Old 04-19-2016, 07:29 PM
brgjag's Avatar
I now when I took my old connector off I just took a screw driver to it to bust it off. I was not keeping it.
julesjag1
04-23-2016 10:17 AM
oldemacdonald
04-18-2016 07:31 PM
Jandreu
04-14-2016 02:32 PM
oldemacdonald
04-14-2016 01:36 AM
wa3ra
04-12-2016 07:40 PM
Quick Reply: Heater hose from engine connection
