Heater idiosyncrasy
Heater idiosyncrasy
In a normal car when you drive you gradually get heat and after a couple of miles full blast from the heater.
But on my 97 jag you can drive 10 miles ,get no heat then leave the car for about an hour and when you start up instant heat . Any thoughts on this ? The pump is running and all pipes hot.
My reply to another thread on heater issues. May work for you
"One thing you could try would be to unplug the electrical connector at the valve and see if that makes a difference. When i unplugged mine, it made a massive difference. When my temp is set at say 75deg, my 97 starts blowing warm air within a half mile from the house when cold, then gets nice and toasty, then after a few miles, the temp drops off. When i turn mine to high, itll make you open the windows, almost like standing too close to a bonfire! As i was told, when you unplug the connector the valve defaults to open so you'll have constant heat, and BOY DID IT WORK FOR ME! I think my issue is possibly my internal sensor, but try unplugging the heat valve and see what happens. Pretty easy to plug and unplug"
Reasons for no heat are
Blocked heater core is very common ..take pipes off and fill with flush agent.
Heater pump not working ..access is very difficult.
Valve stuck closed ..defaults to open if disconnected. I assume the sensor below the steering wheel controls the valve so maybe the thermistor is faulty. ( temp rises resistance falls.....temp falls resistance rises )
Timeisrelative (10-30-2022)
In the photos above if you pull the black plug which is the one to the pump motor and check the resistance across the plug pins you can check if the motor is ok ..if its reads open circuit the motor is buggered. a few ohms then its ok.
Am going to have a go at the thermistor behind the kick panel ...called the aspirator assembly ....a thermistor and a small fan .open circuit the thermistor will make it think its very cold ..easier to get at if it affects the air con in the summer
Timeisrelative (10-31-2022)
The hose furthest to the right of the picture is bent at such an angle that the hose almost seems too flat for water to get through. I think I read that someone else had said that on this forum before but I can't find it again. Could that "folded, possibly blocked off" hose be the problem of poor heat? It looks like from the diagram of the hose/heater system that there could be a longer hose put into place that would not require such a sharp bent angle. What do you think?
I think its a trick of the camera, but ill try to remember to look at it in the morning. My heat works VERY well when its turned up to high, or when the plug is unplugged. Ive only driven 2 days since i cleaned out the temp sensor, but it seems to have made the temp stay more constant at lower temps
Timeisrelative (11-01-2022)
Received 2,400 Likes
Understood. All I am saying is, since most all of the XK's on this forum are, or have had heating issues, that "maybe" this closed off hose "could" be part of the issue??? If a different, longer hose was installed, would that help? I guess there is no way to know without actually installing such a hose.
