Help!!!!!!!!!
Bigvettefreak (10-23-2011)
On your shifter plate there's a plastic six-point (I recall) screw. Under that is the release so you can get out of Park when your electrical is out.
Thank you for telling me about the fuse boxs at the ends of the dash.
I pulled open the drivers side and within seconds I found the 15amp fuse , replaced it and everything is working again.
Did you know that if you blow that fuse you will not be able to get the car out of park? The release is on the interior light fuse as well.
Thanks again.
Thanks again.
